63 chevy impala disc brake conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2007, 02:30 PM
i went ahead and bought the brakets from ccp. i was needing to know what hoses, master cyl,booster,propvalve, and brake line for discs... i am not exactly sure what i need to do i this conversion thanks for the help
Old 12-11-2007, 11:11 PM
63 impala disc brake
i ordered the caliper brakets from ccp and i was wanting to buy the rest peice by piece does anyone have any advice for me about master cylinder booster and prop valve?????????
Old 12-12-2007, 08:11 AM
forestrytodd's Avatar
Official Hotrod Forester
If you are just going for a driver, then you can use the booster from any newer large GM car (impala, caprice, cady). Just make sure that the booster came from a car that had the same set up (disc/drum or disc/disc). Get the whole booster, prop valve everything. You might even get the petel as well. Then take it home and start figuring, you might have to fab a bracket or drill some holes to mount the booster. I would go the extra length and go ahead and replace all the brake lines as well and use only silicone fluid. IMO its the only safe way to do things.
Old 12-12-2007, 10:34 AM
poncho62's Avatar
Wiki Edits: 5
The company that you bought the brackets from should have given you that information. I bought mine from Scarebird.com and they gave me that info.
Mine use s10 Blazer rotors and calipers..........Monte Carlo MC and proportioning valve.
Old 12-12-2007, 01:43 PM
do u know what year the monty carlo was for the master cyl,booster and prop valve?
Old 12-12-2007, 02:03 PM
poncho62's Avatar
Wiki Edits: 5
78 to mid 80s...................
Old 12-12-2007, 04:27 PM
You can avoid all the guessing and get your brakes perfect by going with a Summit G3905 adjustable proportion valve,
http://store.summitracing.com/partde...5&autoview=sku
and a Master Power VL3526 metering block.
http://www.mpbrakes.com/products/pro...product_id=615
I went with the Scarebird swap too, #1 in my book!
Old 12-12-2007, 08:43 PM
do you bolt it up just like a gm prop valve what about the mtering block
Old 12-12-2007, 09:33 PM
Here's a couple photos.
I made my own brake lines. If you make loops don't make them higher then the master.
ID:	26117   Click image for larger version
Old 12-12-2007, 09:38 PM
63 Master cyls go with the booster.
If you have a bolt on cap is usually a Delco Moraine if its a snap ring cap is usually a Bendix.
I used a disc/drum 72 Bonneville Bendix master cyl, it fit perfectly.
1962 Impala disc brake conversion 62impala Suspension - Brakes - Steering 9 01-03-2014 07:57 PM
Ford Galaxie Disc Brake Conversion CrashFarmer2 Suspension - Brakes - Steering 5 04-10-2010 04:52 PM
Heidt or SSBC Disc Brake Conversion Kits? twborbely Suspension - Brakes - Steering 5 06-27-2007 01:12 PM
66 impala disc brake conversion help helrazr3 Suspension - Brakes - Steering 7 03-27-2005 11:43 PM
Rear Disc Brake Conversion for '73 Impala hduff Suspension - Brakes - Steering 11 10-22-2004 03:34 PM
