63 Corvette steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2007, 06:31 AM
frankenvette's Avatar
Go ahead kid squeeze the wheez
I am replacing the original steering column in my 63 with an Ididit tilt column and was wondering if anyone knows if the 63-67 and 68 steering wheel hub adapters are the same bolt pattern. My understanding is the only difference is the notch on the 68 hub.
Old 11-27-2007, 08:04 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Hi: I am going to move this thread to Suspension-Brakes-Steering. You will get more and better answers there.
Dan
Old 11-27-2007, 08:51 AM
Thank you Dan!
Old 11-27-2007, 07:22 PM
I'm going to do the same thing with my '63 Vette. I planned on going with Flaming River. I talked to the rep at SEMA and they stated no adapter was needed.
Good luck on your swap.
Old 11-27-2007, 07:40 PM
My interest is in being able to use the later steering wheels, ie, post 68. They have a shallower dish, and smaller diameter, and are generally much cheaper. Guess, I'll call Ididit to get the answer.
Old 11-28-2007, 08:01 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Ididit's columns will use a 69+ wheel and adaptor.
This is a good thing when you consider some wheels pre-69 have a very deep dish.
On my 59 Elky, I had to trim the lower column bezel about 1" and use a 69+ wheel to put the steering wheel rim in the stock location.
That tilt mechanism adds a couple of inches to the length of the column.
(tilt and shift will add even more)
Old 11-28-2007, 07:58 PM
I have a 14 steering wheel I ordered from Summit. they stated it was to replace the midyear Vette steering wheel. I like it but I want the tilt for convience.
Good luck.
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 10:38 PM
interior paint for steering column corvette dmx6 Body - Exterior 3 10-26-2007 08:17 AM
Steering Column Install Quarter Flash Suspension - Brakes - Steering 3 05-10-2007 12:36 PM
Steering Column for 1971 Chevrolet C/10 glayman Suspension - Brakes - Steering 13 02-24-2007 02:08 PM
Corvette steering column loose woody51 Suspension - Brakes - Steering 4 01-28-2005 04:29 AM
