Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 63 falcon project "stalls in drive"
Old 07-28-2009, 09:34 AM
matt167 matt167 is online now
Wiki Edits: 31
all the symptoms you describe are the result of worn out points.. I had a '65 Rambler that did the same thing.. great smooth idle, but stalled when put in drive... when I checked the dwell was out about 20* even tho they were gapped correctly..
