-   -   63 falcon project "stalls in drive" (http://www.hotrodders.com/forum/63-falcon-project-stalls-drive-162399.html)
bigrobdog 07-27-2009 11:33 PM
as soon as i put it in drive it stalls . unless the idle is real high.why is it doing that.its got the 170
matt167 07-28-2009 09:34 AM
all the symptoms you describe are the result of worn out points.. I had a '65 Rambler that did the same thing.. great smooth idle, but stalled when put in drive... when I checked the dwell was out about 20* even tho they were gapped correctly..
