63 falcon project "stalls in drive" - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2009, 11:33 PM
as soon as i put it in drive it stalls . unless the idle is real high.why is it doing that.its got the 170
Old 07-28-2009, 09:34 AM
Wiki Edits: 31
all the symptoms you describe are the result of worn out points.. I had a '65 Rambler that did the same thing.. great smooth idle, but stalled when put in drive... when I checked the dwell was out about 20* even tho they were gapped correctly..
New project? Before turning a wrench, get organized! Centerline Hotrodding Basics 71 03-10-2013 11:29 AM
The Car Music Project: garage band with instruments made from an old Honda hoodoo Hotrodders' Lounge 0 07-22-2005 12:08 AM
New Site Feature: Project Journals Jon Hotrodders' Lounge 8 01-08-2005 10:10 AM
ATTN: Project of the Week Submitters Jon Hotrodders' Lounge 3 04-22-2004 12:04 AM
Thanks to Project of the Week submitters Jon Hotrodders' Lounge 0 12-06-2003 10:23 AM
