63 falcon (trans - rearend) swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2002, 01:20 PM
New Member
Question 63 falcon (trans - rearend) swap
Put AOD on back burner. Leaning toward C-4 with higher rearend ratio. What C-4 to use and complete rearend will work without a lot of changing? Have a friend with a granda 8" is this the correct width? All suggestions appreciated. (Mel)
Old 04-14-2002, 01:30 PM
mustang66maniac's Avatar
Ford Freak
Post
Try to get a C4 from 67 and up. They have a better valve body than the previous ones, this alows you to hold each gear without shifting and then downshifting to hold a gear. You can also get better shift kits for these. I dont think they changed a lot after that though.
Old 04-16-2002, 05:03 PM
New Member
Post
A 77 Maverick 8" will bolt right in and is 56.5 inches wide wheel mounting flange to same. Later, Jay
