63 Ford F100 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2005, 05:02 PM
63 Ford F100
Does aqnyone know if there are dropped spindles that will fit stock 63 ford f100 axel? Or any tricks you know of like early frod merc moving left spindle to right and right to left. I want to lower this turkey in the front and don't want to sub frame it. Any help appreciated! thanks
Old 11-07-2005, 06:17 PM
BOBCRMAN@aol.com's Avatar
No such thing as dropped spindles for a beam axle. You can try mounting the axle on top of the springs, take out a few of the spring leafs or do it the correct way with a dropped axle. Check with street rod suppliers. Speedway, MAS, etc.
Old 11-09-2005, 04:20 PM
63 ford f100
Thanks for the input. I do plan to move the spring pads on the rear to drop it by mounting over the spring. Didn't think about doing that in the front. I will look for a more significant dropped beam axel in the catalogs as you suggest.
Ford Ranger V8 Conversion nightrain_rod Hotrodders' Lounge 53 07-15-2009 10:45 AM
63 ford falcon van quite a few?? FATHER CHUCK Suspension - Brakes - Steering 15 02-07-2005 02:53 AM
Henry Ford in Heaven schnitz Hotrodders' Lounge 9 10-19-2004 10:09 AM
52 ford f100 flathedflynn Transmission - Rearend 6 10-16-2004 09:38 AM
63 Ford Changing Ignition auntiemame Electrical 0 06-25-2003 10:56 PM
