63 Ford Fairlane starting. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2008, 10:37 PM
GMCTRUCKS's Avatar
OK members I have a buddy that needs help I told him you all are the greatest whats happening is he has a 63 Ford Fairlane with a 289 engine he said that when he hooks up the hot wire to the solenoid the engine starts to turn over by it self any ideas? Thanks! RJ
PS-I sure miss Doc.
Old 06-19-2008, 10:19 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
When you say Hot Wire, are you talking about the battery cable to the solenoid, or the keyed start/crank wire? Also is he installing a new solenoid?
There is only 1 wire that hooks to the "S" terminal, which comes from the ignition switch. The "I" terminal has 1 wire the goes to the coil while cranking. The main battery positive cable goes to the post(usually) closest to the "S" terminal. All other accessory power wires hook there also. The other battery cable to the starter hooks on the other large post.
I've never tried this, and I don't know what would happen if you hooked up the solenoid back-wards. Maybe he is installing it up side down.
Old 06-19-2008, 05:56 PM
Wiki Edits: 31
If the wire for ignition bypass goes to the S terminal, it will do that..
Old 06-19-2008, 06:17 PM
My 2 cents worth
Wiki Edits: 3
Hey Matt!
36 years of working on cars for a living, I've never seen this. My question to you is, How do you know this? LOL
Old 06-19-2008, 06:26 PM
GMCTRUCKS's Avatar
63 Fairlane starter.
Battery cable to the solenoid.
Old 06-19-2008, 06:33 PM
Wiki Edits: 31
Originally Posted by carsavvycook
Hey Matt!
When I did some wiring on my Falcon, I tied the relays switched power from the I terminal.. wasn't paying attention and hooked them up backwards
Old 06-19-2008, 06:55 PM
My 2 cents worth
Wiki Edits: 3
Take a ohm meter and measure the ohms from the battery cable post to the S terminal, with the wires disconnected. If you find any resistance the solenoid is bad.
Old 06-22-2008, 09:17 AM
Obviously the solenoid is closed.
It should be normally open until the S (starter) terminal from the ignition switch triggers it for start.
Probably bad solenoid.
63 ford gear box ( Fairlane ) 2112jb Suspension - Brakes - Steering 4 07-11-2012 12:42 AM
56 Ford Fairlane engine/tranny swap tony1955 Engine 8 12-04-2006 10:04 PM
1964 Ford Fairlane D.W.Decker Introduce Yourself 1 05-23-2006 05:28 PM
starting 66 ford fairlane project DPGSMN Introduce Yourself 2 12-06-2004 07:39 AM
63 Fairlane, 260. Biggarmike Engine 0 01-28-2003 04:49 AM
