Thread Tools Search this Thread share on Facebook
  #1
Old 11-30-2001, 04:21 AM
Bill Wilson Bill Wilson is offline
Question 63 Ford Falcon Ranchero
I am thinking about puting a 351C in my
63 Falcon Ranchero. But not sure it will fit
between the shock towers. And will I have to
cut the hood. I would like to keep it stock
looking for a sleeper. w12bill3@yahoo.com
Register now (free) or login to remove ads
Old 12-01-2001, 04:13 PM
Tom Tom is offline
Post
It will fit but you are going to end up with a funny exhaust system where a 351W would be a better fit and more conventional exhaust also has more available parts, better aftermarket heads and can use the EFI stuff, the oil system is better in the 351W and is more responcive at lower rpms
Old 12-03-2001, 11:27 AM
Post
Thanks for the info. I already had a 351C I also
have a 302 so I will go with that. Thanks again.
Old 12-11-2001, 06:17 PM
elcamino72's Avatar
elcamino72 elcamino72 is offline
Gearhead
Post
302 should fit no problem use the stock exhuast manifolds if you can.
Old 12-18-2001, 08:46 AM
Lee Lee is offline
Post
Lots of mods to fit the 351C, check out this site
http://home.maine.rr.com/fordfalcon/index.htm
Don has a 62 Falcon 351C. The 302 fits well using 64/65 Mustang V8 mounts they are a 3 piece deal, frame mounts, a spacer, and a rubber/steel engine mount. Windsor Fox has the trans mount and crossmember.
Lee
Old 12-19-2001, 04:15 AM
Post
thanks for the info about the trans and crossmember. that will be a big help. I
would like to use a aod but not sure which
one to use? any info ?
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
