Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 63,Impala brake problem
Old 05-12-2006, 07:06 PM
63'Impala Brake Problem.
I put the rear end on blocks,started the engine,while in neutral the rear wheels spin free for a minute, then the right wheel slows to a stop. I put the trans. in Drive they turn for a minute or so then the right rear slows to a stop. To pull the right rear drum, I had to hit it a few times around with wood & hammer to free it. After the drum is off, the shoes are kinda shifted toward the back.The Brakes seem to have preasure applied by just letting the car engine run.I want to drive it. What causes this? the pedal rod is adjusted right.
