Originally Posted by derwood3
hey guys I have 63 impala with manual brakes. I would like to go
to power brakes with the front changed to discs. ,
derwood3
Check this out
disc brake conversion kits
View Part
58CBK-S
5964CBK-S
5864CBK-D
Description
1958 Chevy Stock height conversion - No new Spindle
1959-64 Chevy Stock height conversion - No new Spindle
1958-64 Chevy 2" Drop conversion - New Drop Spindle
Upgrades
Cross Drilled & slotted Rotors
4 wheel disc prop valve
Stainless braided front brake hoses
Disc brake conversion brake line set - OEM Tin Coated
Disc brake conversion brake line set - Stainless Steel
Conversion brake Line clip set
For pieces of the kit - upper or lower kits - click here!
Stock Spindle Disc Brake Kit - This kit retains the stock height of the car using the original spindle. The kit moves the front wheels out 3/8" on each side and works with most 15" wheels.
Drop Spindle Disc Brake Kit - This kit drops stock height of the car 2" using a drop spindle. The kit moves the front wheels out 1/8" on each side and works with most 15" wheels.
Complete Kit Includes (All New Parts): Disc Brake Caliper Bracket Kit, Rotors, Calipers, Pads, 9" Smooth Face Booster, Master Cylinder, Disc Drum Valve, Valve Bracket, Master to Valve Lines, Brake Hoses, Bearings, Seals, Banjo Bolts, Crush Washers, all Misc. Hardware and installation instructions. Drop Kits also include the drop spindle.
1958-64 Cars came with a single master cylinder that feed the drum brake system. The power disc brake system upgrades to a dual master cylinder and proportional valve. This allows the brake fluid system to be separate decreasing total system failure if one line is compromised. If your stock Chevy is in need of disc brakes this is the setup for you. Also offered is a 2" drop spindle kit. This kit lowers the car using a drop spindle. When upgrading to disc brake the car should be upgraded to 3/16 brake line, this size line build up more pressure and gives a much better pedal feel. 3/16" line is commonly used for disc brakes while 1/4" line is used on full drum brake cars.
