63 impala front disc brake lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2008, 11:06 AM
hello hotrodders,
i am puting discs up front in my impala. i got the master cylinder and prop valve but no lines. the original master cylinder had 1 line, and the line the goes to the rear is on the passenger side of the vehicle, what r my options here ? thanks for any advice...
Old 02-03-2008, 11:37 AM
Its very simple. The front brake line from the valve down to the frame and out to the disc brakes. The rear line down to the frame and connect to frame with coated clips and self tapping screws to the rear. Just run them neatly and tucked up so that they dont snag anything.If you need I have pics of this from my 63 Imp.
Old 02-03-2008, 12:38 PM
thanks for your help can i see your pics please?
Old 02-03-2008, 07:01 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
You could also buy the lines already bent and for your application.
I got mine a CPP
www.classicperform.com
There are other vendors as well.
This will be one hard line to the left front from the valve
one to the right front from the valve
and one that should connect to your existing line on the passenger side to the rear.
So---instead of only one line running from the block on the left front of the car,
There will be 2 separate lines running from the P-Valve, down across the front crossmember. One for the rear and one for the right front.
63 impala front disc brake conversion derwood3 Suspension - Brakes - Steering 6 12-27-2012 05:04 PM
63 impala simple disc conversion PikFabrications Suspension - Brakes - Steering 21 01-05-2008 02:12 PM
HELP!!! 39 Dodge front brake lines Madd Syntst Suspension - Brakes - Steering 3 09-23-2006 12:15 PM
front brake flex lines stea Suspension - Brakes - Steering 3 07-06-2004 08:10 PM
Front disc brake conversion ideas oldsjetstar Suspension - Brakes - Steering 2 11-24-2003 08:53 AM
