Thread Tools Search this Thread share on Facebook
  #1
Old 07-06-2011, 01:46 PM
impalaman63's Avatar
impalaman63 impalaman63 is offline
63 Impala -- Nothing works
I have a 1963 Impala all stock. I went for a ride on Sunday, car had NO problems.Tried to start the car on Monday NOTHING - NO lights,radio,interior lights NOTHING car will not turn over or even click when I use the Ing. switch. I have a New battery 1 week old, full charge at 13.7 volts, just checked it . Checked and cleaned the negative cable connection at the block. [IMG][/IMG] Positive cable looks tight at the starter. I did not clean the Positive cable at the starter yet. Could the solenoid be shot and not be letting any juice through?[IMG][/IMG]
Last year New Ignition switch,voltage regulator,neutral safety switch and horn relay.
Any ideas
Register now (free) or login to remove ads
Old 07-06-2011, 03:24 PM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Start at the pos batt terminal and work your way back to the fuse block.... ie neg side of multi meter clamped to a good engine ground.... should get x volts at the pos terminal, if so move down to the other end of the pos cable etc....
Old 07-06-2011, 03:55 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
Check the ground cable that goes from the back of the head to the firewall. These are known to rot off or be left off when work is done.
As mentioned above get a good ground on the block and start at the positive battery terminal and work out from there.
Just looked at a schematic, all the power feeds junction at the horn relay.
Chet
Old 07-06-2011, 04:14 PM
sqzbox's Avatar
sqzbox sqzbox is offline
My pipes are my music
Inline fuzable link from solinoid to the block on the firewall.
Old 07-06-2011, 04:58 PM
poncho62's Avatar
poncho62 poncho62 is offline
Last journal entry: 51 Ford F1
Wiki Edits: 5
There are no fuseable links in these cars.......I believe
I had a 64 Chevy one time....Everything electrical would just die from time to time....I would stomp on the floor near the fuse box and it would come back on.....Turns out it was the contacts in the connector piece at the firewall.......
In the words of Walter Cronkite..."And that's the way it is."
Ontario Rodders
Old 07-07-2011, 07:21 AM
I have
13.7 volts at starter
0.37 volts at Alternator
0.37 volts at Regulator
0.37 volts Horn relay
Now what?
Old 07-07-2011, 08:19 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
May help>> http://www.madelectrical.com/electr...hevymain1.shtml there's a note about 1963-1968 cars.
Other electrical tech>> http://www.madelectrical.com/electrical-tech.shtml
Old 07-07-2011, 08:55 AM
[IMG][/IMG]
Might be this firewall connector.
Old 07-07-2011, 09:40 AM
0.37 volts at fire wall connector. I don't think this is enough.
Old 07-07-2011, 10:46 AM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by impalaman63
I have
Now what?
Find the broken wire(s)
Chet
Old 07-07-2011, 01:02 PM
Should I have 13+ volts at the alternator bat terminal when car is NOT running?
Old 07-07-2011, 01:17 PM
T-bucket23's Avatar
Wiki Edits: 26
Yes that is connected directly to the battery. I would check the junction at the horn relay
Chet
Old 07-07-2011, 01:54 PM
This is the way my manual says it should be wired.( 1963 Impala)
I have 13.7 volts to the horn relay but only 0.37 volts at the voltage reg.
Old 07-07-2011, 02:04 PM
T-bucket23's Avatar
Wiki Edits: 26
According to the schematic I have that is the junction for the whole car. I would disconnect the battery, take that junction aparat and check for corrosion or a broken wire.
Chet
Old 07-07-2011, 02:11 PM
My mistake junction connection is CORRECT.
I only get 0.37 volts at the connector plug.
Could the horn relay be shot?
[IMG][/IMG]
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "63 Impala -- Nothing works"
ThreadThread StarterForumRepliesLast Post
Nothing WorksFiveFeezyElectrical1501-14-2008 06:28 AM
Switching 63 Impala to 64 Impala heat controldmaggardInterior209-13-2006 07:17 PM
Works for me...NXSSite Suggestions and Help302-18-2005 04:26 PM
how it worksbracketeerTransmission - Rearend101-17-2005 10:31 AM
Hope this works.HemmiGremmieHotrodders' Lounge008-23-2004 08:57 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
