63 impala simple disc conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2002, 02:18 AM
Post 63 impala simple disc conversion
hello, i am new to the board and had a quick question on doing a disc brake conversion on my 63 impala. it looks like s10 front 2" drop spindles would bolt-on to my factory ball joints and tierod end. s10's also have the same bolt pattern as the impalla. could i use the entire s10 front spindle, rotor, caliper, and hub assembly to run disc brakes on the front of my car? would the factory master cylinder work or would i have to change to something else? could i just install the front assembly and hook it to the factory brake lines? my knowlage of brakes is very limited so any help would greatly be appreciated.
btw the car is being torn apart right now for fitment of a compleate air ride suspension which will lay frame rails with 20 inch diameter wheels up front and 22 inch diameter wheels out back.
thanks in advance for any help pretaining to the subject!
Old 01-30-2002, 12:15 PM
New Member
Post
I don;t know about the S-10 parts, but doubt they would fit. I am pretty sure that Stainless Steel Brakes has a conversion kit for your car. You would want to update your master cylinder to a dual reservoir system in any event.
Old 01-30-2002, 01:52 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
I do know that you are going to have to change to a dual master cylinder and also a proportioning valve. Also your flex lines will need to be different to fit your disc brake calipers. Check with Roy at the RBBO club, he is an old GM technician , he can tell you for sure what you need.
[ January 30, 2002: Message edited by: Henry Highrise ]</p>
Old 06-02-2003, 04:02 PM
Post
ok everyone print this out
buy it yourself cheaper Impala disc brake conversion
get rotors from
69-74 nova
70-72 monte carlo
67-72 chevelle
69-72 gto
69-72 grand prix
69-72 buick skylark
69-72 buick grand sport
69-72 buick apollo
use the bearing and seals for the car you u choose to get the rotors from
calipers
75-75 nova
73-76 monte carlo
73-76 chevelle
73-76 grand prix
73-76 GTO
73-76 tempest
must use original power brake booster from 61-64 impala
must use a master cylinder from 71-72 impala deep cup bendix part number 10-1496
71-80 gm combination valve
73 chevelle brake hoses
must buy brackets for the calipers, many places in super chevy magazine sell them cheaply!!!
Old 06-02-2003, 07:34 PM
black66's Avatar
www.airriderz.com
Post
I have a Impala also....Here are some links for what you are looking for.....
<a href="http://www.classicperform.com/" target="_blank">http://www.classicperform.com/</a>
<a href="http://www.performancesuspension.com/" target="_blank">http://www.performancesuspension.com/</a>
<a href="http://www.yearone.com/welcomepagecomponents/welcome.html" target="_blank">http://www.yearone.com/welcomepagecomponents/welcome.html</a>
These shops will have everything you will need. If you are going with 20's you should invest in a 13 inch rotor up front. I have 18's all the way around with 235/50's and went with the 13 rotors front and back from Bremmo. My car stops as good as my Mom's new Z-O6.
Old 09-11-2005, 01:00 PM
New Member
63 impala disc conversion
you may be surprized to know that gm rotors were same 68-78 they changed the spindles.same with most gm cars.find a good brake supply and the #'s may be different but same rotor.the reason for certain year cut-off was metric studs! mark at www.scarebird.com can also help and they have laser cut brackets cheap.he has kit that uses s-10 rotors.check him out. good luck
Old 11-18-2007, 06:59 PM
What Spindles Would U Use On This Do It Your Self?
Old 11-18-2007, 07:32 PM
31 five window
Last journal entry: grill and rear end
Stock 63 spindles with custom caliper bracket.
Old 11-18-2007, 07:35 PM
DO NOT use later spindles on your 63. GM changed the taper on the ball joint studs in the mid-70s. While you can physically bolt the later spindles onto the early ball joints, the tapered stud will not seat properly in the spindle and will be prone to breakage. Not a good idea. You CAN get tapered reamers from Speedway Motors to modify the later spindles to fit the early ball joints, but then you have the steering problem. Your 63 has rear steer (steering linkage behind the axle centerline). Newer cars have front steer (linkage in front of the centerline). The spindles won't work - and no, they don't swap side-to-side. I'd suggest you get a lot more informed about brakes before attempting such a swap.
Old 11-18-2007, 07:51 PM
poncho62's Avatar
Wiki Edits: 5
Use stock spindles....and go to this site.......www.scarebird.com ...there are no other spindles that will fit.
Old 11-19-2007, 05:20 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Joe,
55-57 is rear steer
58-64 is front steer
65+ is rear steer------------I'm sure it changed again in the mid 70's (73?)
Bryan
Old 11-19-2007, 06:22 AM
dudes! i have a pair of the brackets from mark at scarebird for my 64' belair wagon and not only are they very reasonable but the quality shows. scarebird not only has quality brackets but excellent tech support. most of the time when you go for the least expensive you end up with junk and a disconnected phone number. when mark says"bolt on" they are
Old 11-19-2007, 07:19 AM
can u use this
get rotors from
69-74 nova
70-72 monte carlo
67-72 chevelle
69-72 gto
69-72 grand prix
69-72 buick skylark
69-72 buick apollo
calipers
75-75 nova
73-76 monte carlo
73-76 chevelle
73-76 grand prix
73-76 GTO
73-76 tempest
can you use these parts along with the original spindles and make it work? it sounds flaky if you ask me but im no expert
Old 11-19-2007, 07:53 AM
poncho62's Avatar
Wiki Edits: 5
63impalass.......you don't seem to want to listen, so I will spell it out.
You can use your stock spindles. You have to buy some brackets to mount your calipers to. Our suggestion here has been for you to buy a pair from scarebird.com. They are about $120 for the pair. They come with instructions on what calipers, rotors, MC and prop valve to use.
There are probably other brackets that you can buy elsewhere.........but, the consensus has been that the scarebird ones are pretty darn good.
1959-64 Chevrolet Impala, SS, Bel Air, $125*
http://www.scarebird.com/6928.html
Old 11-19-2007, 10:53 AM
Originally Posted by Bryan59EC
Joe,
55-57 is rear steer
Bryan
Really? The 58-64 Olds B-body cars are rear-steer. I know the frames on the Olds are different from the Chevy, but I assumed the steering was similar. I guess not. Sorry for the mis-information.
By the way, 65-70 B-bodies are the same. The frame was changed for 71-76 with front steer and the different ball joint taper.
