63 nova rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-10-2006, 06:49 PM
63novamn's Avatar
63 nova rearend
Just seeing if anybody new what rearend bolt up pretty easy into a 63 nova rear end.
thanks
Old 12-10-2006, 06:54 PM
risaacp's Avatar
More Horsepower Than Brains
Last journal entry: Check it out
only 62-67 novas will just bolt right up. You can upgrade from what you probably have, the old style with a third member to a 64 to 67 10 bolt 8.2. Or if your lucky and find a 12 bolt nova rear. The price on that will be on up there though.
Old 12-10-2006, 06:57 PM
Any 62-67 Nova rear, any 75-80 Granada/Monarch/Versailles rear, any 57-59 Ford rear, any 64-65 Mustang rear, some Mopar A-body rears and possibly an early Bronco rear.
Old 12-10-2006, 07:03 PM
63novamn's Avatar
i know nothing will just bolt right up, i guess im looking for about the same length rearend to put in. Do any s10 rear ends measure up the same?
Old 12-10-2006, 07:14 PM
These will bolt right up, I have personal experience with them:
Any 62-67 Nova rear, any 75-80 Granada/Monarch/Versailles rear, any 57-59 Ford rear, any 64-65 Mustang rear.
I've never personally installed a Mopar A-body rear or a Bronco rear, but there is anecdotal info at Steve's Nova Site.
S-10 rears will fit with some mods, and there are a couple of widths you have to choose from. I saw a S-10 disc rear under a 63 but it took some welding.
Old 12-10-2006, 07:28 PM
risaacp's Avatar
I stand corrected! good luck
Old 12-10-2006, 08:03 PM
63novamn's Avatar
will 66 spindals fit my 63? I got 4 bolt and want to go to 5 bolt.
Old 12-10-2006, 08:52 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Im in the same boat pal! Im currently in the process of narrowing a ford 9'' for mine. Moser sold me the housing ends and spring perches, and gave me the exact specs to build my own housing. pinion angle, housing length, center lines etc. Its costing me about 1k to do this. Im using mostly used stuff and getting the axles re splined and shortened. If you need those specs I will list them. I know that seems like alot of money, but when finished I will have a very tough rear end.
Old 12-10-2006, 09:45 PM
Yes the 66 spindles will fit. You will also need the steering arm and hubs. The steering stops on the 62-63 lower arms are different and will increase the turning radius if you don't change anything.
Old 12-11-2006, 12:06 AM
63 nova rearend
65-67 spindles bolt on. you can upgrade to disc's using gm a body parts 68-72, bolt on swap with minor mods. ford granada or lincoln versilles will work ( lincoln had 2 bolt patterns) if you do go to 4 wheel disc's 65-66 corvette manual master cylinder works good. i had this setup on my 66' ss. don't forget if you use the ford or lincoln disc rear make sure to hook up the e-brake or it will not work properly. i had issues at first and that was the problem. adjustable proportioning valve for rears balances system out. good luck!
Old 12-11-2006, 01:17 AM
jvsapp's Avatar
just a gearhead in paradise..
Last journal entry: last ones for now.
please post the specs,. i have a buddy that needs them so he can setup a ford 9 for me.
i also have 66 spindles on my car, but i have seen a chrysler 8 3/4" under several novas. supposed to bolt in, but i can't remember what year they came out of. there was a guy that had a post on another site that the s10 rearend in certian later models are same width, but the pearches are different. i think i googled them. or was it on ebay... damm i can't remember.
Old 12-11-2006, 06:52 PM
Bowtie or Die!
Here they are :
GM Housing ends
Housing width= 52 1/2"
Pinion offset= 1/2"
Pad center line= 43 1/2"
Pinion angle= 2 deg down
Pads toe in= No
Axle lengths= 29 7/8"& 26 1/2"
These specs are straight from Mosier engineering I called and asked them when I ordered my parts and they gladly helped.
Old 12-12-2006, 03:30 PM
63novamn's Avatar
Thanks for all the help, i found a nova 67 rear at my local junk yard.
Old 12-15-2006, 03:46 AM
jvsapp's Avatar
grab the spindles if the are still there...
Old 12-16-2006, 09:29 PM
Mustangsaly's Avatar
thanks
mid 90s ford explorer rear will, most are 8.8s with 373 posi and disc brakes. ask here http://www.stevesnovasite.com/forums/
http://nnnova.com/discbrakes.html
http://www.parts123.com/parts123/yb....~A0~~~~~A10~A1
I will add more links tomorrow
Mustangsaly
using an S10 chassis under 63 nova 63Pepper Suspension - Brakes - Steering 32 10-01-2012 02:33 PM
rearend swap for a nova nova63and66 Transmission - Rearend 10 11-10-2005 07:34 PM
63 Nova Front & Rear Seats Mustangsaly Interior 3 10-13-2005 10:44 AM
63 nova discs jtdchevy Suspension - Brakes - Steering 6 05-11-2004 12:35 PM
Rearend For Nova novachad Transmission - Rearend 3 05-29-2003 04:16 AM
