63 olds f85 front lower arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2013, 03:47 AM
does anyone know how to remove the lower control arm pivot from the subframe? i have everything stripped to this point, but the threaded bars seem solid - and i don't want to 'get a bigger hammer' as there may not be any going back. i'm in england and this is a bit of a rare item over here. ie. there are no spare parts. thanks - any info would be helpful.
Old 01-09-2013, 04:16 PM
...here's a pic of the front end of the threaded pivot bar...
Name:	lower control 1.jpg
Old 01-09-2013, 08:06 PM
There is a Kent Moore tool that threads onto the shaft and locks in place. This allows you to unscrew the shaft from the crossmember. A pair of regular nuts threaded on and torqued against each other will do the same thing.
The Following User Says Thank You to joe_padavano For This Useful Post:
350bmw (01-10-2013)
Old 01-10-2013, 01:36 AM
thank you Joe - you're a star. wasn't sure if it was a threaded in bar or just drifted in. thanks again
63 cutlass, 63 f85, 63 olds, lower control arms
LOWER CONTROL ARMS. PLEASE HELP Pro1972nova Suspension - Brakes - Steering 4 03-01-2012 09:19 PM
Lower Control Arms globb Suspension - Brakes - Steering 1 05-28-2011 01:28 PM
lower control arms runn141 Suspension - Brakes - Steering 5 05-02-2007 04:49 PM
Mll Lower Arms solidaxel Suspension - Brakes - Steering 2 09-04-2004 10:54 PM
LOWER A ARMS FOR MUSTANG II DAVIDTEDDYBEAR Suspension - Brakes - Steering 3 03-05-2003 01:07 PM
