63 Rambler rearend ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2010, 12:21 AM
Roxanne's Avatar
What year make(s)/model(s) of rearends will fit a 1963 Rambler Classic best? I'm leaning toward a Ford 9", but I'm open to suggestions. I'd like to get the best fit I can for the least amount of modifications...I'm not a fabricator! What types of mods will be necessary? I'd like to do the entire rear swap if possible (suspension, brakes, etc). as a complete unit. Is this even possible?
Old 08-01-2010, 08:47 AM
BOBCRMAN@aol.com's Avatar
What type rear suspension is it? It's been a while, but I have done mid sixties AMC cars and they were torque tube rear with coil rear spring.. Not a simple swap.. As for compatible leaf spring rear ends. S-10 is very universal..
Old 08-01-2010, 12:01 PM
Wiki Edits: 31
PM Farna. he has done this swap and knows what parts are needed.. it's not simple, but there are off the shelf parts that can be made to work. I think for a Monte Carlo IIRC... best rear is the AMC 20 from a '66 and later Classic/ Ambassador
Old 08-01-2010, 12:46 PM
Roxanne's Avatar
Yes, its tq tube and coil springs setup... but that will change.
I'm changing to a 327 sbc, haven't decided on tranny (its between a 700r4 and a 400). I'm not interested in dragging the car, just a nice street performer. I was just wanting to get some opinions on rears, what the easiest swap and if the whole rearend assembly could be swapped instead of having to piece it together.
I realize the engine and trans are chevy, the rear (possibly) is a ford, and the car is an AMC....I'm for equal opportunity in the reliability dept.
Old 08-01-2010, 01:17 PM
Wiki Edits: 31
AMC drivetrain is just as reliable as a SBC.. '67 and later V8's will bolt in with parts from a later car. and it won't kill the value of the car... a 360 or a 401 would really help move that car along, and nither is very hard to find as they came in Wagoneers.. pair that with the 700- R4 with an adaptor that is readily available
the rear suspension will need to be peiced togther. there is no suspension ( not even OEM AMC ) that will just bolt in place of the torque tube setup
Old 08-01-2010, 01:50 PM
sqzbox's Avatar
My pipes are my music
You might measure a rear end out of a hornet and if you get lucky, even an old S/C 360. They had Dana limited slip third members in them that will interchange with different model's of AMC. If I remember correctly, the hornets had a narrower axle than the other models. As far as the tranny, why not go with the TH350? It's lighter and has a lower first gear. TH 400's are heavier, and 700R4's get complicated with Tv cables and lock up controls. The TH350 is easily modified and installation with the sbc is simple.
Old 08-01-2010, 01:54 PM
sqzbox's Avatar
Not saying the hornet will interchange but the fit under the rambler classic might be what your looking for.
Old 08-01-2010, 02:37 PM
big gear head's Avatar
High Performance Rear Ends
What is the overall width of the rear end? Will you be welding spring perches on the rear end and using the stock leaf springs?
Old 08-01-2010, 03:18 PM
Friend of mine has a 64 Rambler wagon. He put a 8.8 rear out of a 1994 Ford Explorer, and used 4 link suspension set-up.
Old 08-02-2010, 10:05 AM
Roxanne's Avatar
I had thought about the explorer 8.8, but didn't know if it would fit. I have found lots of info on different Rambler models, but not much about 63 models. I'm not a Rambler expert, but I think the 63 year was somewhat of a transitional time for them. Some things on there are 'leftovers' from Nash, etc., some things from 64-up will fit, but so will some things leftover from Nash.
To answer one of the above questions: I have not measured the rear length yet. (Its 105 degrees here with 95%+ humidity, I'm not going to battle that!) As far as suspension goes (I know that goes under a different topic, but just to answer the question...) I haven't decided, I have several possibilities-4 link, coil-over, airbags. That will depend on whatever is easier with the rearend I end up choosing.
As far as the reliability of AMC, there's no question they're reliable, the parts are just difficult to find and expensive if you do find them. (My car had been parked for over 10 years, after a few teaspoons of marvel oil and several days of soaking, she turned right over!) I'd challenge anyone to do that on one of today's cars 50+ years from now!
Old 08-02-2010, 10:28 AM
Roxanne's Avatar
I meant to include the TH350 in the possibilities, just forgot to. 700r4s are more complicated, but its a possibility only for mileage/driveability purposes. Although I doubt it will help noticeably, since the 327 has been bored 40 (and may go 60), has a 274 cam, and vortec heads. Not sure it would even be worth it to put in in there.
Old 08-02-2010, 01:53 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I'm a big fan of the 700R4/4L60 trans, they work great in street and strip cars up to about 400~450 hp, and even further if properly modified. You can run a higher rear gear, and a higher stall speed lockup converter and have the best of both worlds, mileage and drive-ability AND performance,
Old 08-02-2010, 02:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Be sure to get all the parts of the rear end when/if you get one from another vehicle.
Drums or rotors, calipers or backing plate w/hardware, axles, brake lines, driveshaft- the works. There's no reason other than possibly the axle/wheel bolt pattern that all this can't be reused on your Rambler, as-is.
Old 08-05-2010, 01:13 PM
Roxanne's Avatar
The wheel bolt pattern is ford, which is why I was leaning more toward a ford rearend than others, less work when the front suspension is redone. I know they can be drilled, but I had rather not add yet ANOTHER thing to my list. There's plenty that needs to be done without adding anything else!
Old 08-05-2010, 01:32 PM
Roxanne's Avatar
I was intending on getting the whole rear assembly if it would work (or only require some basic mods), that's what I'm trying to find out. I know the driveshaft will have to be made.
So which rearend is better, 8.8 or a 9"? Uh-oh, here comes that can o' worms.... Maybe I should clarify.... Better for MY particular application and setup? Or are they both about the same in my case?
63 rambler 287 onobill Engine 2 10-19-2008 03:35 PM
63 nova rearend 63novamn Transmission - Rearend 15 12-17-2006 02:37 PM
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 07:23 PM
need info on 63 lemans rearend swap 63lemansconvertible Transmission - Rearend 6 04-29-2005 02:32 AM
63 falcon (trans - rearend) swap melbishop Transmission - Rearend 2 04-16-2002 06:03 PM
