64/65 muncie wide ratio? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2003, 11:37 AM
New Member
I am looking at what I'm told is a rebuilt 64/65 muncie wide ratio 4 speed. Is this an M21, M22, I don't know. I have some numbers off of it. Main case 3851325, tail housing 3846429, side cover 3831707, front cover 3915020, and date code po624. What is it i'm looking at? Any info is appreciated
Old 10-19-2003, 12:30 PM
BOBCRMAN@aol.com's Avatar
Easiest way is to put the trans in low gear, mark the input and output shafts, turn the input shaft and count how many revolutions it turns to make the output turn one. If it turns two and one half turns, it is a 2.54 or wide ratio. If it turns two and one quarter turns it is a 2.20 or close ratio.
Old 10-20-2003, 12:57 AM
Try here:
http://www.dandltransmission.com/muncieratio.html
