64 Buick Nailhead Specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2008, 07:35 AM
RACER805's Avatar
Last journal entry: HOOD SCOOP AND RIMS
need torque specs for a 64 buick 401 nailhead.any other info you might have to share would be a big help.
Old 05-25-2008, 10:47 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Do an internet search for Buick Nailhead, there's a lot there. The '64 Nailhead was 364 ci ('57-'66, 2nd gen). They came with 9.5:1 cr and 250 hp, with an optional 10:1, 300 hp version available.
http://www.carcraft.com/thehistoryof...ead/index.html
http://www.buickthunder.com/
Semper Fi
Old 05-25-2008, 04:42 PM
techinspector1's Avatar
Wiki Edits: 326
Unless I'm reading it wrong, the Car Craft article you referenced shows the 401 and 425 as the available engines in '64.
Old 05-25-2008, 10:14 PM
Last journal entry: more sheet metal stuff
64 nailhead was either a 401 or 425. go to www. Buicks.net and there you will find all the specs you need. all 64 Rivieras came with a 425 and it was rated at 465 ft lbs and 360 hp. the 401 was standard in all other 64 big cars and was rated at 325 hp and 445 ft lbs of torque.
Buick 401 Nailhead - questions heyjude076 Engine 13 03-22-2008 12:18 AM
Ideas for a Buick 401 Nailhead ckucia Engine 5 05-20-2005 10:51 AM
My son is replacing the trunk floor in his 64 Buick tm454 Hotrodding Basics 1 06-14-2004 09:04 AM
64 Buick Electra ian marsh Engine 2 12-23-2003 05:21 PM
Nailhead Buick Manual Flywheel(s) DJM Transmission - Rearend 2 11-09-2002 07:51 PM
