64 c10 crossmember - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2013, 07:19 PM
Last journal entry: engine
64 c10 crossmember
I have a 64 chevy c10 cross member that the passenger side bracket that bolts to the frame and hold the upper control arm is broken where the bolt holds the control arm. The problem I have is that I spent $100 to get one of another 64 but after cleaning both of the brackets off, neither one is salvageable due to rust eating through them. I have already bought the disc conversion kit and was hoping to find one that bolts up and can use them. If you have any options please let me know...mustang II???? I will post pics soon.
Old 02-24-2013, 07:38 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I used a 73-87 (mine is from a 1976 C10) front clip, which was pretty much a "bolt-in" on my 66. See my project journal.
64 used coil springs too, didn't it?
The Following User Says Thank You to 66GMC For This Useful Post:
chevy64c10 (02-26-2013)
1964 Chevy C10 front crossmember problem Hotrod1979 Suspension - Brakes - Steering 12 12-23-2012 05:44 PM
Crossmember Megatron Introduce Yourself 1 10-09-2007 09:45 AM
crossmember redneckhotrodder Transmission - Rearend 3 08-31-2007 07:18 PM
M ll Crossmember Gr8 '48 bow tie Suspension - Brakes - Steering 1 02-04-2006 07:15 AM
Crossmember help! D88 Transmission - Rearend 8 10-23-2003 10:30 PM
