64 chev chevelle disc brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2003, 07:10 PM
Post 64 chev chevelle disc brakes
i am tring to find out what spindles i can us to install disc brakes
Old 02-05-2003, 10:04 AM
F-1Rodder's Avatar
Post
Since discs were not available on any GM car back then, there is not an interchange. I would suggest that look to companies like Master Power Brakes and similar companies for an updating modification. It will be expensive.
Old 02-07-2003, 02:55 PM
ssaza's Avatar
Post
67-72 chevelle,GTO,Lemans,GS,skylark,442,cutlass,70-72 monte carlo,gran prix disc brakes spindles assy. will bolt onto your 64 chevelle,stay away from 67-68 disc brakes,as they are 4 piston calipers and very $$$ to fix.67-69 camaro and 68-74 nova spindles will work if you put your chevelle steering arms on.It is a easy change over.{Bolt on]
Old 02-07-2003, 04:53 PM
Post
hi everone
<img src="graemlins/nono.gif" border="0" alt="[nono]" /> <img src="graemlins/boxing.gif" border="0" alt="[boxing]" />
Old 02-18-2003, 10:02 PM
Post
You can use disc brakes from 68-74 nova 70-72 monte carlo is the one to check out because most of them have F41 suspension..means rear sway bar and boxed control arms..these monte carlo swaps have kept 4 of my cars covered in disc brakes and rear handling to boot! Dont overlook the monte carlos from 70-72!!
Old 02-19-2003, 10:58 PM
Post
check out http://www.performancesuspension.com/main.htm
they will have everything you need for your ride....
Old 02-08-2004, 03:06 AM
64 Chevelle w/ 1986 700R Transmission
I have a 1964 Chevelle and I purchased a 1986 700r Transmisson.
I know I need to change the drive-line and I just purchased the lockup kit for the torque converter...
My question is, since the trans came from a 1986 camaro iroc.... the back portion of the tranny doesn't look like it will match the crossmember. i know I need to move it back and possibly cut and reverse the mounting plate....But the way it mounts from the transmission...doesn't look like it wilkl work.
Do I need to find another backend of another transmission to make it match the mounting plate...If, so... What do i find?
roqwire@hotmail.com
Old 02-16-2004, 01:21 AM
64 malibu disc brakes
WildChild ; Im in Natalbany , on Cherry St. I Have what you need. Spindles ,etc. off 74 GTO ( same as Nova) ; going to put on my 63 nova . I have calipers , mounting brackets too! Now can you guys tell him what all he will need . email musky70401@yahoo.com or 985-386-9292 after 7 pm ( I also have tons of Chevy parts plus 9 inch Fords , Chevy rears and rear discs for both.
Old 02-16-2004, 10:30 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
A kit sells for about $900.00--$1000.00, You can pick up the necessary parts for a bolt on plus some new parts at the local parts store for around $300.00 or less. Good Luck
The knowledge base is full of info. for this project. check Jons post in the lounge.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 02-17-2004, 03:47 PM
Thom Laybourne's Avatar
Hot Rod Mags
Just check a few of the hot rod magazines. You will see a display of almost every thing you would need. Some of the advertisers like Chevell Classics sell kits for yours. But the best way is to visit the bone yard. Those guys will tell you what to get and what should be new. The home work is easy and fun. GL
hr41pearl
Old 03-03-2004, 09:41 AM
scotts82's Avatar
Thumbs up disc brakes
there is a website you can go to www.classicperform.com and you can get a catalog for your car i put a disc brake kit on my wifes 68 nova fit perfect. they have a kit for your car i already looked( go for it.
Old 03-15-2004, 12:12 AM
Does Wilwood make a set that fits over your existing spindles? I used one of their front disc kits on my 65 Mustang. Very easy swap.
Ron
Old 04-12-2004, 01:00 AM
lust4speed's Avatar
What ssaza said. I will add that the cheapest way to do it is to take everything from a donor car of the proper vintage. This will include not only the rotors, calipers, and spindles, but also the brake lines, proportioning valve and master cylinder/power brake assembly (including the rod between the brake pedal and the booster). You are then assured of a balanced system. The master cylinders are totally different between drum and disc brake cars, and so is the proportioning valve rates. Even after buying new pads, turning the rotors and rebuilding the calipers you will have a little less than half of what you would with the aftermarket kits.
But if you want to spend the money, the aftermarket stuff is sweet...
Old 04-24-2004, 06:23 PM
67 Nova 400sbc.4L60
Re: 64 Chevelle w/ 1986 700R Transmission
roqwire@hotmail.com
Does the tailstock on your 1986 700R4 have three holes going through it . If so that is OK Just modify the cross member so you can bolt the mount to the rear bolt holes in the trans case. If You want to you can get a pickuo truck tailstock from another 700R4 .(4L60)
Old 04-24-2004, 08:56 PM
My front kit disc from Wilwood was $475.00. 2 new steel braided lines were $16.00. A M/C from a 74 Maverick was $75.00. I also liked having new parts instead of 40 year old parts and the weight savings was about 60 pounds off the nose.
Ron
