64 Chevelle floor pans - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2002, 12:54 PM
Post 64 Chevelle floor pans
I have a 64 Chevelle 2 door hardtop. I also have a 64 4 door sedan with a good floor pan.has any one tried to interchange and if so what modifications were required ?
Old 12-26-2002, 02:44 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Post
4 door pans should fit the 2 door. I know on my '62 that a 4 door Belair is the same as a 2 door Impala. I sold the pans and firewall from the Belair to a friend that is using them in a convertible. He is like the resident expert when it comes to Chevies especially '62. Are you going to use the rockers also or just cut the pans out. If just cutting the pans..on the donor car...cut everything way bigger than what you need. First off, gut the car. Seats, glass, dash, everything that will come unbolted. You can either use some of this stuff later or resell it on Ebay. Pull the doors off. If you are going to use a cutting torch to cut the donor floor out, pull the body off the frame. This can be done with 4 people. Roll the car on it's side and cut from underneath. That way you can see what is going to be in the road. Like I said, cut everything much larger than you need and make sure you don't cut the braces. After removing the floor you can sell the car for the going scrap rate. BTW the 4 door frame should be the same as the 2 door frame so you have a spare you can clean up and paint. On the floor that is coming out of the 2 door you can (and is preferred) use a spotweld cutter. If you do not have access to one you can use a cutting torch. Cut everything smaller than what you need. You will also need good snips, preferrably electric shears, air chisel, and a good set of ear plugs. It is just a matter of cutting, trimmimg and fitting now. Take your time as it is not a very easy job to replace a floor. I done it in my '62 and it took a few weeks and everything still did not fit up right. I used aftermarket parts and had it in before I found the donor car. Factory parts fit much better. Before you weld in the new make sure you clean it of any undercoating, have it sandblasted, and ready to prime when you weld it back in. I think I covered most of the basics but if I didn't someone else will fill in what I missed. That's what's great about this board.
Kevin
Old 12-26-2002, 07:22 AM
New Member
Post
I was wondering if anyone has put a 49 or 50 chevy body on a complet newer frame AND, floor pan.??? i have a 49 chevy coupe body, (but the frame is completely rusted in several places, and i want to put this body on a newer floor pan and running gear from a donor car with similar wheel base, anyone know of a good donor car to buy,???all help would be appreciated,(i already have the 49 body off the original frame ) Thanks, Al,...
Old 12-26-2002, 07:55 AM
Kevin45's Avatar
Post
First thing to do is measure the wheelbase of the '49 then cross reference it with newer Chevys to see what will come close or right on, then go from there. Practically anything can be put to anything if you got the know how. A group of friends, a bunch of brew, and watch the ideas fly!!!!!
Kevin
Old 12-26-2002, 08:01 AM
New Member
Post
[quote]Originally posted by streetrod936:
<strong> I was wondering if anyone has put a 49 or 50 chevy body on a complet newer frame AND, floor pan.??? i have a 49 chevy coupe body, (but the frame is completely rusted in several places, and i want to put this body on a newer floor pan and running gear from a donor car with similar wheel base, anyone know of a good donor car to buy,???all help would be appreciated,(i already have the 49 body off the original frame ) Thanks, Al,...</strong><hr></blockquote>
