64 Chevy Impala throttle cable for quadrajet - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2013, 10:19 AM
OK I am getting closer and closer to being able to drive this car lol. I need someones advice on how to do my throttle linkage for 64 Impala. I have a 454 w quadrajet and a 700r4 trans behind it. The old style gas pedal on the Chevy pushes the rod to the carb. Well the quadrajet looks like its a cable setup to pull the throttle on the carb so i am looking for any ideas to remedy my situation. Any help would be great!
Old 02-16-2013, 10:24 AM
poncho62's Avatar
Wiki Edits: 5
If I remember correctly, the rod still pulls the carb linkage, as does the cable setup.....It will work with your big block....or you could adapt a cable setup from an early 70s GM
Ontario Rodders
Old 02-16-2013, 02:43 PM
Your memory serves you well!! Had one of my kids press the pedal and yes it does pull lol
Old 02-16-2013, 02:50 PM
If your 64 impala was an original 6 cylinder car the lever coming out of the firewall is probably pointing down and it would push instead of pull. Remove the lever from the splined shaft and replace it so that it is pointing up and towards the front. If the lever has a dog leg in it you may have to cut it apart and weld it back to get the correct shape.
Grind the peg off the qjet for cable setup and it leaves a hole just right for the throttle rod for a 64 impala.
Old 02-16-2013, 02:55 PM
delawarebill's Avatar
cable
when doing my bucket i looked at all the cables on the mkt.. they were too long and to cut one to fit was throwing money away.. went to a local bicycle shop and got brake cable and the chrome fittings for the ends... alot cheaper and works great.. i have seen walmart carries the cables too.. just another option.
Old 02-16-2013, 03:02 PM
Thanks bill and nun. Poncho was right I feel like an idiot for making this thread. Yea it pulls so I'm all good just have to get a cable. Thanks again guys sorry for wasting anyone's time
Old 02-17-2013, 06:40 AM
u wasted time...
by say'n your an idiot.. not true.. i figure if U think its a dumb question u don't know the answer.. then it becomes a valid question, leaving only dumb answers.. ask away, gotta be someone thinking the same but afraid to ask..
Old 02-19-2013, 06:26 PM
Anyone ever use this kit? Summit Racing® Throttle Cable and Kickdown Cable Pro Packs 03-0042 - SummitRacing.com
Old 02-20-2013, 12:53 AM
JeffB's Avatar
Very user friendly and EZ to set up but will work better with a different pedal because of the way it attaches.Might look at this:http://www.ebay.com/itm/Billet-Throt...sories&vxp=mtr and Lokar Hi Tech 700R4 Kickdown Kit KD 2700HT | eBay
Old 02-20-2013, 04:03 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In some cases the Q-jet throttle arm can be used in a "push" application by using (or making) a hole in the throttle arm below the throttle shaft c/l. Thing is, not all Q-jets have that part of the throttle arm, like many later model manual trans apps (example shown below).
Old 02-22-2013, 02:54 PM
Ok now I am running into problems with attaching my tv cable to carb. I know I need a geometry plate but where do i find one to fit a quadrajet???
DBW throttle control or strait cable throttle?? chadman322 Hotrodding Basics 0 09-03-2012 02:21 PM
Using Chevy TBI throttle cable on carb brad33478 Engine 2 02-23-2012 08:55 PM
Chevy I6 Throttle Cable Conversion klutchmaster427 Engine 7 01-11-2012 06:04 PM
Impala throttle cable ratboy7070 Hotrodding Basics 3 05-16-2010 12:31 PM
Throttle Control..Cable / Lever & Rod/ Or Electronic ( Throttle By Wire) Viet Nam Vette Engine 4 06-13-2005 04:29 PM
