64 Chevy Panel Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2010, 01:32 PM
Trying to find out what chassis swap would work best for my 64 panel truck. Some say 80's model short wheel base will work. Any info would be helpfull.
Old 01-15-2010, 04:12 PM
SSedan64's Avatar
You didn't give much Info.
Make?
Engine, Trans & Rear you want to use?
Offroad/Onroad use? etc..
Old 01-15-2010, 05:31 PM
Chevy S10's are the best bet. You'll need to check the wheel base and maybe have to make some modifications to adjust. Width of the S10's are the same as yours.
Moreover, pull the master brake and booster along with the brake pedal assemblies if your going to convert to disc brakes.
Old 01-16-2010, 12:31 AM
kc0kfg's Avatar
kc0kfg
umm
The S10 track width is only 54.7 quite a bit narrow for a 60-66, as for the short box its not the right length.
Why the need to do a total frame swap ? unless your panels frame is rotted or bent up its a great design and it has all the mounts for your body.
If you want to spend the cash there are plenty of company's making parts to lower and improve the handling and the braking.
Now If you are like many of us and prefer the DIY route you can swap 73-86 upper and lower control arms and gain disk brakes, many swap the center section of the frame as well.
My 66 is running 86 upper and lower arms,spindles and disc brakes on the front and air bags on all corners
If you look over at stovebolt or at 67-72 chevy each site has a 60-66 board and plenty of info.
Old 01-16-2010, 10:53 AM
60-72 used the same chassis. You need to go under and take measurements of one. I know these chassis well. We use them under 30's ford body ratrods because they are narrow.
Old 01-16-2010, 12:02 PM
life is a temporary assignment
As far as I know,,A 80's model Chevy truck front end will bolt right end on your frame with very very little mod's..
Old 01-16-2010, 12:08 PM
That is absolutely true. The k frame will bolt right on with no modifacions. Maybe the original poster will give us more of an idea of why he wants to swap chassis.
59 Chevy truck body on 80-85 Chevy frame? texczech General Rodding Tech 11 08-18-2011 08:24 PM
New arrival: 1958 chevy panel truck trucktony Introduce Yourself 3 02-10-2009 09:29 PM
46 Chevy Truck 64 Impala Ss Olskool And A Few Others Hello Hotrodders BOXER957 Introduce Yourself 2 11-30-2008 10:14 PM
46 Chevy Panel Mike Edwards Introduce Yourself 2 05-10-2006 08:34 PM
64 chevy truck c20 davetc Introduce Yourself 1 08-22-2004 06:56 AM
