64 chevy pick up - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2010, 08:50 AM
64 chevy pick up
i recently bought a 64 Chevy pick up 4x4 body's wonderful shape no rust every-things there except the motor n trans i payed 350 for the truck saved it from the crusher so if you guys could please point me in which motor would be best id really appreciate it will try to get pics of both Ranchero n Chevy up soon
Old 04-16-2010, 08:53 AM
DoubleVision's Avatar
What`s the plan? Do you want to restore it or drop in a engine and use it for a mud runner? hunting truck? If so a 350 small block will suit you fine.
Do you plan to do a build? buy a crate engine? Performance? stock?
Old 04-16-2010, 08:59 AM
im thinking of restoring it because the truck its self is not in bad shape at all only a little surface rust under the passenger door needs new chrome but thats about it but i was thinking about a stock 350 or a 305 so not the original motor but not a power house either but i don't know which trans i should get
Old 04-16-2010, 09:20 AM
sqzbox's Avatar
My pipes are my music
Your going to need more than just a tranny. You have to think about the transfer case also. I have a 350 cu in with a TH350 and NP203 transfer and manual lock outs. When un-locked, only the rear drive shaft turns in 2wheel hi and low which saves fuel when on the road.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Installing front cab support on 64 Chevy pickup Bluesbrother Body - Exterior 10 06-02-2009 09:04 AM
64 chevy swap davetc Transmission - Rearend 3 12-26-2008 03:15 PM
1946 Chevy Pick Up "Black Out" Steve H/46 Pick Up Introduce Yourself 2 04-19-2007 10:59 PM
1950 Chevy pick up frame strength Dave 55 General Rodding Tech 6 03-24-2007 09:49 PM
