'64 Corvair brake lights
Got a '64 Corvair and all of the lights work EXCEPT the left brake. Has a new turnsignal switch and bulbs are good. Can't figure this one out.??
That's the strange thing. The turn signal DOES work and it's a new switch at the column. OH nice Chevy -my car is about the same color.
I assume these are 1157 bulbs? Start with the basics. Have you verified power at the connector? Have you verified ground? Does the running light filament work? Does the turn signal work with the lights both on and off? The 1157 has both filaments connected to a common ground. If the socket ground is bad, one circuit will often ground through the other filament, leading to unusual behavior of the lights. Check the ground.
| master cylinder interchange | runn141 | Suspension - Brakes - Steering | 7 | 05-03-2009 05:15 AM |
| Brake lights stay on | Techguy_2000 | Electrical | 3 | 10-16-2007 08:43 PM |
| Added LED Brake Light,works only with lights off! Help! | TheBreeze | Electrical | 7 | 09-06-2005 10:58 AM |
| Corvair Disc Brake Conversion | tcruise | Suspension - Brakes - Steering | 3 | 08-31-2005 12:16 AM |
| Brake light/turn signal lights wont work together | ChevyForever | Electrical | 1 | 10-04-2004 01:19 PM |
