64 corvette fuel level wiring
if someone can please help me i have a 64 corvette that i have instaled a auto meter gas gage in. it has the stock sender in it also. i am using a painless wiring harness and can not get the fuel system to read right. the problem the vette sending unit has 3 terminials on it one has a s ( i would think this is the sending terminal) one has a i ( dont know why) and one i guess would be the ground. i have wasted over 30 hr on this trying to wirer it different ways, if some one could help i would be gratfull. thanks
Doc here,
Are you talking about the TANK sending unit , or the DASH gauge? On the DASH gauge: S=SENDER I=12 VOLTS SWITCHED G=GROUND I is NEVER used in a sender..you DO NOT want 12 volts immersed in 30 gallons of gasoline.. The Sender should be, Hard Ground, and Sender wire to the gauge. Doc
Aftermarket Solutions Electronic & Electrical Innovations |
thanks very much
can you make it clear to me what is a hard ground. thanks i have been going crazy with this
Doc here,
HARD ground.. Battery Neg to frame to device... Or battery to device ground. Things like a ground wire on a strip of metal under the dash are questionable as to bonding a good ground. Doc
| Aftermarket EFI ? | x007 | Engine | 61 | 02-08-2012 10:38 AM |
| '98-'02 Corvette wiring diagrams? | cacsmret | Electrical | 4 | 01-26-2010 11:36 AM |
| I'm going to make a bonfire out of my car | blown69stang | Engine | 36 | 08-22-2005 03:36 PM |
| fuel lines for 1967 corvette | minesoar | Engine | 2 | 09-14-2003 06:20 PM |
