Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 64 corvette ground straps
Old 03-26-2011, 10:02 PM
35terraplane's Avatar
35terraplane 35terraplane is offline
ground straps
Originally Posted by GMR
yep, 327NUT has it right, looking for factory locations please. I have the assembly manual, the '63 shop manual and the '64 supplement - but can't find the ground locations in those. They may be in there but I sure can't find 'em.
I had a 63 too, but I don't remember, that was 50 years ago. Did you know you need grounding terminals for the inside. With what you said you put the ground from the battery to the starter bolt, the whole works should have a good ground to the frame, right now you are depending just on bolts that go from running gear to frame, and if there was paint on them you would not have a very good ground. The best place to do this would be from the engine. Just food for thought, GM had to run one somewhere.
Bob
