#1
64 el camino wheel size ???????
i have a 64 el camino with the springs cut and fenders rolled. i have a 12 bolt for the rear. would a 275/60/15 tire on a 15x8 with 5in backspacing fit? i should i go 5 1/4in backspacing?
Register now (free) or login to remove ads |
#2
I see this has been unanswered for a while..........and the reason is, Who Knows. These kind of things takes trial and error, sometimes you can borrow a wide wheel/tire combo from someone. You could also buy the Percy's Wheelrite wheel and tire simulator. these are available at Summit, Jegs, Speedway etc.
#3
Probably have better luck on a Chevelle or ElCo site.
Some Info: http://www.chevellestuff.net/tech/tire_wheel.htm http://www.chevellestuff.net/tech/wheel_offset.htm http://www.chevellestuff.net/tech/t...ll_markings.htm From the Tech Section >> http://www.chevellestuff.net/tech/index.htm |
| Thread Tools | Search this Thread |
| Similar Threads for: "64 el camino wheel size ???????" | ||||
| Tire size vs. wheel size | Ratdoggy | General Rodding Tech | 7 | 11-11-2009 07:00 AM |
| 67 12 bolt in a 70 el camino help on tire and rim size | elcaminodragster | Transmission - Rearend | 0 | 10-19-2009 07:09 PM |
| wheel size? | runn141 | General Rodding Tech | 6 | 01-15-2009 03:09 PM |
| What size wheel | chevellenut | General Rodding Tech | 0 | 01-12-2007 10:11 PM |
| El Camino Wheel Hop | wheresyamotor | Transmission - Rearend | 3 | 01-29-2003 05:39 AM |
