Originally Posted by brucesfairlane
does anybody know of good and safe spring compresser tool
The best kind to use on those cars is a type made especially for Fairlanes and Mustangs of the 60s etc.
remove the shock upper mount tower, and use a flat plate across the top of the hole.
The lower end of the spring should also get a flat plate with little tabs welded on it to keep it centered in the spring. The coils are angled. (These 62-65 Fairlanes do not use a lower spring cradle and the spring sits directly on the upper control arm. The spring takes a set and gets permanently curved because of this.)
Then you suck the spring upwards into the top of the shock tower and remove the upper control arm, etc.
Then release the spring downward.
Do NOT use all thread unless you get 1" diameter, it is too soft and can break. Also the threads are so coarse that cranking the nut takes a lot of effort, but it can be done. A compressed spring will have 2-3000 pounds of pressure on it.
The 62-65 Fairlane spring is about 20" long when released. Conventional compressors don't have enough travel to get them out safely.
I do a lot of these cars and this type is the easiest and safest way.
Check with some Mustang restorers in your area.
