64 Falcon 2dr HT - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 01:24 PM
64 Falcon 2dr HT
Wanting to know who has some guidance on an auto tranny that will support about 380HP. Wanting to move away from 4-speed. What is my best choice (C4, C6, or??), and what do I need to be concerned with to avoid problems. Any tips on 'stall speed'? Rear end is 456 posi. Are there problems in what ratio's the tranny needs to have. How would be the best combination for making it a 1/4 mile car? Thanks!!
Old 01-27-2006, 08:03 PM
onebadmerc's Avatar
I need a bucket of arc sparks
I would run a C4, they are fairly cheap and can take a ludicrous amounts of power. Why run a C6 unless you are running a BB Ford, it takes more hp to push, plus is weights more.
Old 01-28-2006, 08:19 AM
jim..'s Avatar
That 6 Cylinder Guy
Yep, I agree,the c4 will handle the power,but if you want to seriously race,go with a pro built converter with high stall,say 3500 or better,depends on the engine you're using.
An engine built for hp in the higher rpm range,needs a converter that will launch you in that range.
One built for low end torque can use lower stall.
Old 01-28-2006, 10:53 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Hey, Welcome to the site.
A built C-4 is the ticket.
But until you figure how to "hook up" the rear tires.... it wont make much difference.
Crossmember on a tubbed 64 falcon falconpro Suspension - Brakes - Steering 3 12-14-2004 11:51 AM
tubbing a 64 falcon? falconpro General Rodding Tech 3 10-04-2004 11:09 AM
64 Falcon rear end newchevyman Transmission - Rearend 3 04-28-2004 03:04 PM
should I buy either of these for fun 69 nova or 64 falcon DeathByGreaser Hotrodders' Lounge 5 05-31-2003 09:16 PM
64 Falcon tranny swap problems Halteclere Transmission - Rearend 5 12-15-2002 01:46 PM
