64 Falcon Brake Pedal Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2010, 06:44 PM
I have a 1964 Falcon with a bad 4 speed swap. I want to put in a 5.0 with a C4. Does the automatic brake pedal assembly from a 63 falcon fit a 64?
Old 11-29-2010, 06:52 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Not sure but one out of a 65/66 mustang should work in the falcon.
Cole
Old 11-29-2010, 08:53 PM
Wiki Edits: 31
'64-'69 Falcon or '64.5-'66 Mustang will swap, and be 'correct' but I'm pretty sure stang pedals all the way to '68 'fit'.. '63 stuff, altho a lot is the same within the chassis, much is still different
Brake Pedal Has No Pressure klutchmaster427 Suspension - Brakes - Steering 5 10-08-2009 04:40 PM
Brake pedal assembly help APalusky Suspension - Brakes - Steering 7 12-05-2006 06:09 PM
Rock Hard Brake Pedal 64nova Suspension - Brakes - Steering 9 11-16-2006 04:34 PM
Brake pedal to the floor 87442lover Suspension - Brakes - Steering 5 11-12-2004 10:59 PM
64 Falcon tranny swap problems Halteclere Transmission - Rearend 5 12-15-2002 01:46 PM
