64 galaxie - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2003, 06:15 PM
64 galaxie
hey guys i have a 64 galaxie with a 390 i am planning to buy a 73 t-bird to rob the disc brakes off of it what i would to know is if the c-6 bolted to a 460 will interchange with my 390 any help in this matter might help in my decsion in buying the t-bird im also told the spindles will bolt right on is this correct? many thanks willie
Old 11-28-2003, 04:59 AM
FASTFORD's Avatar
390/460 c6
i think the trans should bolt right up,just not 100% sure of this.
SEE THE NEXT POST!!!
sorry i cant help you with the spindles. you may want to check some ford web sites to get better info. g`luck with your ride!
Old 11-28-2003, 08:25 AM
woodz428's Avatar
Troll Hunter
Arrow
460 and 390s use different bellhousing patterns...it won't fit.You need a trans pattern that is for a 352/360/390/410/428 (also 406 and 427s, but they never came with C6s). If you have a cast iron cruiso, you can put a '66 and later FMX valve body with a shift kit in it and have a strong good shifting transmission.The C6 will be found easiest in a '70's era truck with a 360/390
Old 11-28-2003, 02:48 PM
FASTFORD's Avatar
64 galaxy
Thanks Woodz,i just could not remember if all the big blocks used the same pattern. glad you corrected my posting.
now if someone could answer his spindle question......?
Old 03-31-2004, 03:02 PM
I believe the spindles will FIT, but I think they have the 5" bolt pattern instead of 4.5". Phil
