Hotrodders Bulletin Board > Tech Help> Suspension - Brakes - Steering
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 08-29-2002, 11:21 PM
six_fo six_fo is offline
Post 64 impala Brakes
I want to convert to disc brakes I heard i can use them off a 82-92 s10 2wd is this true
  #2
Old 08-30-2002, 01:52 AM
deuce_454's Avatar
deuce_454 deuce_454 is offline
Post
you can use any disc. and any caliper... BUT the labour involved will be different with every swap. i dont know wether the s-10 brakes bolt up or not, but you can be almost sure that useing the s-10 spindles will mess up yous steering geometry. If i were you i would buy a disc brake conversion kit with spindles and all. the money will be almost the same as completely restoring a s-10 setup and bolting it on...
go with a kit!!
Old 08-30-2002, 03:51 AM
roys63's Avatar
roys63 roys63 is offline
Post
You can buy a caliper bracket kit for about $100.00 and use The 11" rotors and calipers Hoses from chevell and malibu this will bolt right up, follow instructions that come with kit,i will find the link to buy this.
Old 08-30-2002, 04:06 AM
roys63's Avatar
Post
OK i found it! try, Classicperform.com They have it all.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
