64 Nova build.. suggestions on a transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2008, 04:25 PM
nobody1031's Avatar
Im trying to plan for all the work that I want to do on my 64 nova but I don't know about the transmission. I am pretty sure that I am going to run a chevy small block (hopefully around 500 hp) and either a power glide trans. or a manual. I like a six speed because of the cruising but I like a 4 speed as well. The powerglide is my back up because I already have one and cause they take so much abuse. If I was to go with a six speed which would I use and how hard would it be to bolt everything up? Im not worried about fabricating a cross member or drive shaft
Old 08-23-2008, 04:37 PM
Crosley's Avatar
Wiki Edits: 1659
Sounds like an interesting project... i like the ol Novas
I edited the thread title to give an idea of what your question was about.
welcome Hotrodders.com
Old 08-25-2008, 06:31 PM
nobody1031's Avatar
Thanks sometimes I don't write what I mean to say. I should also put in there that it is gonna be a weekend warrior not a daily driver
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
327 build up using 1964 and earlier parts ONLY chopperimpala Engine 23 10-06-2005 01:07 PM
Need suggestions on 350 build pete379 Engine 3 06-14-2005 10:10 AM
need cam suggestions for my 383 build TCAMARO Engine 10 12-23-2004 04:51 PM
Finally decided on an engine build up! Adrenaline_Fiend Engine 2 10-20-2003 09:43 PM
