-   -   64 olds Boil Over (http://www.hotrodders.com/forum/64-olds-boil-over-221204.html)
91camaro91 07-01-2012 01:05 PM
64 olds Boil Over
so i posted on a previous thread about my rad. boiling over. everyone suggested that my water pump may be junk. i pulled it, and the propelers were in awsome shape and it spun real good. no probl there. i got a new thermostat and a new rad. cap. i flushed the rad. till that water ran clean, i flushed in BOTH ports for the water pump while it was off, flushed through the heat core too. still it wont draw the water. idk if there is some kind of air buble problem. or not, but when ther thermo opens the water goes no where....im so lost....
LATECH 07-01-2012 01:50 PM
Sounds like he radiator may be plugged.Did you look down inside at the tube ends when you had it drained?
Does it look like the intake gasket was changed? Maybe somebody put the water crossover blocking plates at the wrong end of the motor.
You should be able to pull the thermostat and look in sideways to see if the coolant passage is open to the cylinder heads.
327NUT 07-02-2012 01:25 PM
You can also try running it without the thermostat (stat) and rad. cap to see if the water is flowing through the engine. You don't want to drive it that way, just let it sit in the driveway and watch the flow through the cap opening. If it flows the pump is working and you know the "propelers" ....also known as the impeller is working properly. You can also do this with the front of the car jacked up ...safely with jack stands, in park, emergy. brake on yada yada. This will allow any air bubbles you may have in the block to work their way forward and escape out the open cap.
