Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 64 Pontiac 389 to 65' Pontiac 389
Old 02-16-2013, 10:43 AM
environspec environspec is offline
Hello: I'm looking for a basic answer to my question. I have a set of Edelbrock Aluminum Heads (#61599) for the D-Port Pontiac 389 engine. I also have Edelbrock's 2x4's intake manifold (54501) for the same engine. What I would like to know is that will these heads and intake manifold by chance fit on a 389 {1964 389 Block}. I noted the bolt pattern is certainly different. But when you match the cylinder head gasket to the 64' block and to the 65' cylinder head surface they do match up. Is there any other issue I may have to deal with such as water ports which when focusing on the problem seems to be the only problem. If not, then I'll go with a later block. Thanks very much if any of you Pontiac fans (or certainly others) can provide me this important background information.
