64 rear end swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2005, 07:09 PM
64 rear end swap
ihave a 64 chevy pickup with an eaton rearend and coil springs. i am not sure if i like the coil springs. since i am going to swapping out the rearend for a 14 bolt, i was thinking about changing to leaf springs. can someone help me with the pros and cons of swaping to leaf springs.
Old 10-16-2005, 07:12 PM
poncho62's Avatar
Wiki Edits: 5
Other than re-engineering the whole rear half of the frame......a lot of cutting and welding of brackets.
Why not just trade it for a 3/4 ton model, they have the leaf springs already.
Old 10-16-2005, 08:15 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
Keep the coils. Less axle wrap leading to less wheel hop under hard acceleration.
Old 10-17-2005, 12:23 AM
forgot to mention
i guess i forgot to mention that the truck is a 3/4 ton model. 8 lugs all the way around. the reason i was thinking about the coil/leaf swap, is that i see they only built the coils for a few years. and hard acceleration i not a concern for me. not looking for a hot rod, just a good reliable truck. thanks guys.
rear end swap 91 camaro rs twisted91 Transmission - Rearend 5 01-10-2005 07:25 PM
rear end swap? mshellw Transmission - Rearend 1 04-17-2004 03:42 PM
Rear End Swap Question Weimer Transmission - Rearend 3 05-20-2003 10:08 AM
rear end swap from a trans am to a chevy malibu bigslickwille Transmission - Rearend 3 12-20-2002 03:34 AM
Rear End Swap Chevydude Transmission - Rearend 2 07-03-2002 11:59 PM
