maybe 1/2 a point at the most
engine
engine
283 bored .60 over kb-166 signature pistions .100 dome speed pro street/strip rings stock short stroke 3'' crank proline H beam rods rated at 800 hp arp studs on everything summit hv oil pump summit gear drives comp cams 305H magnum cam duration 253@.050 525 lift comp cams .100 longer push rods crane cams 1.5 long slot roller rockers holly street/strip mech fuel pump edelbrock super victor intake accel breakerless billet distributor,super coil,wires,shorty plugs hooker super competition headers 64cc gm vortec heads that have been modified for the large lift Mighty demon 650 carb My compression is 10.1 now and i was wanting to go with about 10.9-11.1.I'm trying to think of the best way to raise it. |
use a thinner gasket, cut the heads as little as possible, later model heads have thinner decks, the more you cut them the thinner the deck gets, the harder it is to keep gaskets in place. if theres room after the thinner gaskets are figured in, decking the block brings comp. up faster than cutting heads requiring less metal removal, however piston to head & valve clearances become critical and must be checked, and you'l probably want to loose the hyd cam in favor of a solid, the lifters are probably gona float long before the engine starts to get going.
.015 thousands is the thinnist i know of.
