65, 396 pad # Help Please - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2010, 05:29 PM
Need help from someone who knows more than I
apparently. Have a rare 396, 4-bolt BBC casting
3855962, Trying to decode the deck pad numbers.
They are "TII04EF and a "B" to the lower right of the F
Not having any luck on my searchs.
Any help would be great.
Thanks.
Old 07-21-2010, 07:35 PM
Not sure how accurate this info is, but it matches what you have, other than it being a '66, instead of a '65. (but the K-2-5 shows it's a late-'65 block...specifically Nov. 2, 1965) It's actually T1104EF instead of TII04EF.
http://www.vintagebigblocks.com/1770359.html
1966 396 Chevelle 4 bolt 4 speed block, Cast 962 date K-2-5 T1104EF.
Old 07-21-2010, 09:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Casting number is for a '65-'66 396 4-bolt block.
EF SUFFIX:
EF 1966 396 360 Chevelle HP
EF 1967 396 350 Chevelle HP
EF 1968 396 350 Chevelle HP
A casting date in '65 doesn't necessarily mean it went into a '65 vehicle- it could have been used in '66, depending on the month. In the case of an "11", it would indicate your block was cast in November, and would not have been installed in a '65 vehicle.
Old 07-22-2010, 08:44 AM
396, deck pad # help, Thanks
Thanks again. What does the "B" to the lower right of the last letter "F" mean?
This thing has "hi perf" cast all over it...maybe 8 places.
I'll see if I can attch a pic....
thanks again
Old 07-22-2010, 09:18 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
thanks again
I think all the BBC blocks except the tall deck truck blocks were given the "high perf" designation, heads that had high perf meant rectangle ports, "pass" heads were oval. Don't know what peanut port heads or TD heads got- and I even ported a set of PP heads years ago...
Your block being a 4-bolt, really IS "HP", AFA production blocks go.
No idea on the "F", sorry.
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
recovering dash pad esahlin Interior 2 05-13-2009 11:44 AM
Rare 65 Chevelle 396 4 bolt block Fastest65 Engine 10 07-02-2008 09:37 AM
Newbie-- 65 Riviera, 65 Corvette, 65 burb owner fatrink Introduce Yourself 1 07-16-2006 07:18 PM
383 vs. 396 Malibu73 Engine 15 11-30-2005 12:30 PM
