Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > General Rodding Tech
  #1
Old 04-26-2005, 01:24 PM
68Ranchero 68Ranchero is offline
'65 6 cyl. Mustang Head Gasket Problem
When driving my 6 cyl. Mustang on the highway it blows the head gasket on #6.
This is the second time this has happened. It runs fine and cool around town and on the highway.
When the head is pulled the #6 Piston is red in color, all others are carbon black.
The head has been surfaced, valve guides replaced, valves ground. It still blows the head gasket.
Could it be:
1. Carb. leaning out at speed?
2. Warped block?
3. Distributor advance to far at highway speeds?
Any suggestions? This is really low tech but it still is a problem.
Old 04-26-2005, 01:39 PM
Pics
Attached a couple of pictures showing the block.
Size:  180.8 KB  Click image for larger version
Old 04-26-2005, 02:20 PM
tm454 tm454 is offline
Tazz
Buy better gaskets.......
get the Really $expensive$ metal gaskets for the 6banger this time. I know they sell them for the V8's...I wonder if they sell them for the 6's?? Are you using felpro or what?
Tazz
Rat Rods Rule!
Old 04-26-2005, 07:49 PM
Gaskets`
Yes, I'm using Felpro Gaskets, torqued the heads per spec’s etc.
Old 04-26-2005, 08:32 PM
Max Keith's Avatar
Max Keith Max Keith is offline
Blown head gasket X2
Sounds to me like you may have a warped head or possibly even the deck of the block. Get a straight edge thats at least as long as your block. with the straight edge standing on its edge, check both sides of the cylinders, front to rear, then across the deck of the block, left rear to rt front and rt rear to left front. Do this with both the head and the block. Look for any gaps under the straight edge (discounting cylinder bores and combustion chambers). If you see any gaps between the straight edge and the surface you are testing, if you can get more than a .010" thick feeler gauge into the gap, you need to have it machined to get the flatness back.
Old 04-26-2005, 09:07 PM
scholman scholman is offline
re: '65 6 cyl. Mustang Head Gasket Problem
68Ranchero,
I think you have a vacuum leak to that cylinder. From the gray color in the exhaust manifold on that cylinder but the others are black or sooty. Check where the vacuum lines go and which one is right at the back cylinder.
Good Luck
Scholman
Old 04-27-2005, 12:20 PM
Biggarmike's Avatar
Biggarmike Biggarmike is offline
Chief Procrastinator
check the area near the head bolt hole on the R R corner. There is some dark staining from the bolt hole toward the cylnder. you could have a small crack or high/low spot near the bolthole allowing coolant to seep into the combustion chamber when hot or at high RPM. That could also cause the reddish deposits on the #6 piston. check intake and exhaust ports for #6 too. Vacuum leak or exhaust gasket leakage can cause hot spots, making headgaskets fail, even when torqued properly. Those straight sixes are great little engines.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "'65 6 cyl. Mustang Head Gasket Problem"
3.8 Ford Head Gasket Questions RCastle Engine 17 04-11-2005 10:14 AM
Head Gasket installation '67Pony Engine 3 07-27-2003 11:33 AM
chevy head gasket andybird Engine 3 03-30-2003 06:13 AM
head gasket question RiceMuncherdude Engine 2 03-12-2003 03:01 AM
More head gasket questions willys36@aol.com Engine 3 08-13-2002 03:06 PM
