65 Belair rear end & TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2006, 10:07 PM
sabino56's Avatar
I have a 65 Belair that started life with a 6 cyl with 2 speed powerglide and A/C. I recently replaced the engine with a sbc 350 and the transmission with a TH350. I'm told the TH350 is an early 80's vintage with a "universal" housing - ie. bolt pattern for chevy and Buick?.. Anyway, the speedo reads way high. I've read some about changing speedo gears and first thing I need to do is know the rear end ratio. Before I put transmission in I jacked up one wheel (other still on ground) and spun the wheel and counted the yoke revolutions. The wheel when 9 1/2 revs for 16 revs of the yoke. I calculated this to be a 3.38 rear end. Did I do this right? and is this a rear end that would have come with car?
Thanks!
Ed
Old 10-23-2006, 01:25 PM
Chevrolet did offer a 3.36
If you still have the original Powerglide ... pull the speedometer cable and bullet
Like this ..
count the number of teeth on the driven gear
and then count the teeth on the driver gear ( on the output shaft )
Divide the numbers and get the ratio difference ... then duplicate the same ratio in a Turbo 350 set and you should be GOLDEN ...
Old 10-23-2006, 07:52 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you could at least show pics of parts that are close to what is really in a power glide......
Old 10-23-2006, 09:25 PM
http://novaresource.org/speedo.htm
Old 10-23-2006, 10:14 PM
True ... so true ...
If I could find photos of a Power glide parts and pieces on the internet I would ... but the 700R4 stuff is all I could find ( and that what I have in the 3W ) ...
They should be close enogh to give the guy a idea on what to do ...
Old 10-24-2006, 02:26 PM
sabino56's Avatar
Thanks - I do have the original powerglide. I hadn't thought to check it. That's a good idea. One question - I'm not sure how hard it is to see the drive gear. How many different drive gears (ie. different tooth count) were available on a 65 2 spd powerglide? I was thinking I could rough out the gear ratio by turning output shaft and counting speedo gear rev. Then after pulling the driven gear out and counting, if I couldn't see the drive gear I should be able to figure out.
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
ford rear end indentifer 40blackie Transmission - Rearend 15 01-23-2006 07:39 PM
10 bolt rear end. TORI1 Transmission - Rearend 1 01-04-2006 10:37 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
dodge challenger in need of rear end advice. Journier Transmission - Rearend 0 05-28-2004 10:23 PM
