65 biscayne power steering box swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2011, 09:14 PM
Don Meyer's Avatar
I just bought a ex drag car & would like to swap out the 1965 power steering box for a newer 605 type. Borgeson has a box they have come out with to make this possible,but.....$500.
Is there a later model chevy box that will bolt in. I think the bolt patterns are the same, but what about a steering arm.
Thanks Don
Old 05-31-2011, 10:59 PM
Don Meyer's Avatar
No one has any info on a latter model steering box swap for a 1965 impala?
Please Don
Old 06-01-2011, 05:38 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I think you may be limited to 65-70 Full size Chev
You might---not sure---be able to use a box from a 68+ Nova
Can't say for sure if the 'rear steer' and the 'front steer' cars can use the same box
Old 06-01-2011, 06:14 AM
Last journal entry: A few ongoing projects
Hi Don, been a while since I've played with this stuff, but as I recall you will find that the 605 uses a smaller diameter pitman arm shaft. Fortunately the size is the same as used in the manual steering box so you will need to find a pitman arm from a manual steering 65 to make it work.
If you are just looking for a little more responsive steering you might check out the mid 80's G body F41 (performance suspension) steering boxes. They are the older full size design (no pitman arm change required) and should bolt up. These are a front steer box by the way.....I can't remember what the 65s were.
CARDONE part# 276550 $116 thru Rockauto
(look up an 84 Monte Carlo for the application)
The only issue you will run is the current pressure hose you have is probably set up with SAE compression fittings and the new gear will have metric O ring fittings. This can be overcome by either changing the fitting in the back of the pump to an O ring fitting and finding a new hose that will fit or cutting the pump end of your current hose off and putting an O ring end on by using a compression fitting splice. (I originally tried the fitting swap on mine but for some reason it would not work so I ended up doing the splice instead).
Old 06-04-2011, 04:27 AM
Don Meyer's Avatar
great info.....thanks
Don
Power steering swap Chesapeake Suspension - Brakes - Steering 4 11-19-2007 07:08 AM
1959 Biscayne disk brake swap? ad2lap Suspension - Brakes - Steering 2 10-31-2007 04:28 PM
Power Steering swap '64 El Camino billman Suspension - Brakes - Steering 3 10-29-2003 12:45 AM
Power steering swap on a g-body Scuzzy Suspension - Brakes - Steering 0 08-08-2003 11:07 PM
power steering rack and pinion swap Paco Suspension - Brakes - Steering 0 04-03-2002 06:56 PM
