NAPA (Airtex) #E8228 with 5/16" fittings
Attributes
Contents : Hex Nut, Lockwasher, O-Ring, Terminal, Screw, Mounting Bracketting Brack
Fuel Pump Fitting Size[s] : Inlet - .320", Outlet - .320"
Fuel Pump Fitting Type[s] : Inlet - Hose Barb, Outlet - Hose Barb
Fuel Pump Gallons Per Hour : 38
Fuel Pump Pressure Rating : 100-125
or #E8248 with 3/8" fittings
Attributes
Contents : 2 Hex Nuts, 2 Lockwashers, O-Ring, Hose Clamp, Screw/Lockwas
Fuel Pump Fitting Size[s] : Inlet - .37", Outlet - .375"
Fuel Pump Gallons Per Hour : 60-70
Fuel Pump Pressure Rating : 110-120
Summit has a whole bunch of regulators.
I
filtered the list down to what I think might suit your needs.
I see that Summits also stocks the same Airtex fuel pump part numbers that I provided above.
Edit:
You'll also want a fairly decent in-line fuel filter between the tank and the pump.
Fram HPG-1
