65 C10 fuel tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2012, 06:16 AM
65 C10 fuel tank
Hi i got a 65 c10 and i want to put the fuel tank in the rear. Im putting a 6.0 vortec in which needs 55-60 psi fuel. is there a company that supplies tanks with pump assb in them at that psi.or a good frame style pump anyone recommends
Old 12-02-2012, 06:53 AM
delawarebill's Avatar
gas tk
RPM or ron pope motorsports makes them..
he's in kodak TN.
tbucket@comcast.net
865-932-7541
tell him delaware bill sent u...
no i do not get any kick backs, i just know he does tanks..
The Following User Says Thank You to delawarebill For This Useful Post:
lmar1171 (12-02-2012)
Old 12-02-2012, 07:20 AM
65 C10 fuel tank
Check out this tank. EFI or carbureted applications. 1965 CHEVROLET C10 PICKUP Classic Performance Aluminum Gas Tanks 6372AGTBS - SummitRacing.com
The Following User Says Thank You to cdminter59 For This Useful Post:
Old 12-02-2012, 07:47 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
NAPA (Airtex) #E8228 with 5/16" fittings
Attributes
Contents : Hex Nut, Lockwasher, O-Ring, Terminal, Screw, Mounting Bracketting Brack
Fuel Pump Fitting Size[s] : Inlet - .320", Outlet - .320"
Fuel Pump Fitting Type[s] : Inlet - Hose Barb, Outlet - Hose Barb
Fuel Pump Gallons Per Hour : 38
Fuel Pump Pressure Rating : 100-125
or #E8248 with 3/8" fittings
Attributes
Contents : 2 Hex Nuts, 2 Lockwashers, O-Ring, Hose Clamp, Screw/Lockwas
Fuel Pump Fitting Size[s] : Inlet - .37", Outlet - .375"
Fuel Pump Gallons Per Hour : 60-70
Fuel Pump Pressure Rating : 110-120
Summit has a whole bunch of regulators.
I filtered the list down to what I think might suit your needs.
I see that Summits also stocks the same Airtex fuel pump part numbers that I provided above.
Edit:
You'll also want a fairly decent in-line fuel filter between the tank and the pump.
Fram HPG-1
Old 12-02-2012, 08:34 AM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
I isntalled a "Tanks, Inc." '49-'52 Chevy passenger car gas tank behind the rear axle.
Here is a thread I created that gives the basics: Rear Mount Gas Tank 63-72 Short Bed Step Side - ChevyTalk --The Social Network for Chevy Fans
I am runing a carb so I am using the regular mechanical fuel pump. However, Tanks Inc. also has an in-tank fuel injection pump that will work with their tanks. In-Tank Fuel Pump Module - GPA-Series
Old 12-02-2012, 08:57 AM
66GMC's Avatar
Nice-looking job there, Lake.
If and when I ever get around to finishing my fleetside, I was envisioning a 1976 suburban tank, and grafting a fuel filler door to the outer panel. The suburban had about the same width on the frame rails, I think
It would likely take a bit of work to build in some kind of pocket or cover for the filler neck.
Spectra Premium # GM15A
Attributes
Gas Tank Capacity : 25 GAL; 95 l
Gas Tank Height : 28 3/4"
Gas Tank Length : 28 1/8"
Gas Tank Width : 10 3/4"
I couldn't read your dimensions in your diagram.
Does this sound close?
72 C10 Gas Tank Retrofit Custom10 General Rodding Tech 6 11-28-2014 10:10 PM
1968-72 c10 gas tank relocation chevy6869 General Rodding Tech 7 10-01-2012 07:49 PM
How do I remove in-cab Gas Tank 69 C10? coreyboothproject Hotrodding Basics 4 11-05-2010 07:41 PM
Fuel Stink - How to Vent Fuel Tank for Chevy 350 TPI Engine kbuhagiar Engine 5 08-18-2010 07:54 AM
Tank relocation on a 69 c10 CMR Hotrodding Basics 8 09-23-2009 05:21 AM
