65 c10 tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2006, 05:10 AM
67ssguy's Avatar
65 c10 tranny swap
I have a 65 c10 pickup with a 67 250 straight six and a 65 3 speed on the column. I got a setup from a friend to swap in a th400. I plan on keeping the 6 banger for now, it runs pretty sweet, my friend was running a small block. I got the shifter linkage, th400, torque converter, flywheel, and drive shaft. My question is will the th400 be a direct bolt on? Can I use the starter on the 6 cyl.? Any help would be appreciated...
Old 06-20-2006, 06:44 AM
tnsmith10's Avatar
when will it rain???
the trans will bolt up, and all should work, exceptu gotta check the o.d. of the flexplate against the flywheel for ur manual... gotta be same tooth count. (no starter change if so). then, unless u have the same truck, the driveshaft will have to be shortened, or replaced with 1 of the correct length., other than that, ud have to get a kickdown relay for it so ull have passing gear... (no kickdown cable, has electronic kickdown.)
65' GTO... Swap to TH400 65GTO455 Transmission - Rearend 3 11-10-2005 07:12 PM
t5 swap on pre '65 ford 289 flamedfordbronco Transmission - Rearend 2 10-25-2005 05:00 PM
TH-350 - 700R4 tranny swap 73monte Transmission - Rearend 3 03-25-2004 01:26 AM
tranny swap...whats better chevy82 Transmission - Rearend 2 03-09-2004 04:37 PM
manual tranny swap chevyIIdie4 Transmission - Rearend 1 05-13-2003 09:09 AM
