Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '65 chevelle 2dr post headliner moldings?
Old 08-21-2011, 05:11 PM
lngliv3 lngliv3 is offline
DTL,
Thanks for the reply, and after reading some of your other posts, its obvious you know your stuff! Please allow me to pick your brain a little further. I brought my car to my home garage today to get some pictures of the areas im looking at. I can see what you mean about the windlace going all around the front door jam pinch weld areas. The spots that are throwin me off are the "tack" strips that go above the rear quarter glass, down around the sail panels. At this point, Im thinkin another short piece of windlace will do the trick, so now im focused on the sail panels...what holds them thin wafers to the wall? If you can see that "bar" going across the sail panel area? Do these hold the panels some how? Or are they just a tack area for the headliner behind the sails....?
ID:	57727   Click image for larger version
ID:	57728   Click image for larger version
