Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 65 chevelle oil pan removal?
Old 07-13-2010, 05:37 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Been there with a 67 Chevelle, which is the same frame. you can't do it without lifting the engine about 3",..... and by the time you go that far you might as well just pull it out and make the reinstall preocess foolproof for the gasket to be sure you will have no leaks when done
