65 chevelle tire rub...sway bar? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-22-2010, 04:47 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I definitely would roll the fender lips to avoid any sharp edges that may cut a tire if it hits..that is the first thing..as far as alignment get one of these:
http://www.speedwaymotors.com/ECONOM...AUGE,2699.html
this works fine and once i get the fenders rolled I check castor and camber to see that i am within limits..then i can mount a tire and wheel and support the vehicle fom the A-arms (ride height) and turn the wheels both left and right to see where I have clearance..then once i know all of this I can make a more informed choice on wheels and tires..If you have turn tables it can life a bit easier here..
One more thing if you are running springs and need to raise the car just a wee bit make a large "washer" and place it on top of the spring. An 1/8 or 3/16 spacer on the spring can make just enough difference to make it all work..
Sam
  #17 (permalink)
Old 10-22-2010, 05:33 PM
Originally Posted by Tony@AirRideTech
Ingliv.... by the way here is a picture of our shop 66 Chevelle that I drove out to Bonneville and Pleasanton 2 years ago. In the front we are running 275/40/18. That is with stock inner fenderwells and rolled fender lips.
Very nice car and a very nice photo. Yes you can get a lot more tire in there with mods, but even then likely some harmless rubbing. And what's wrong with a little harmless rubbing?
  #18 (permalink)
Old 10-22-2010, 06:04 PM
mud.man.rj's Avatar
tire rub
Springs are cheap, just start with a small block set instead of the 6 cyl set and it won't roll over half as much for sure, a stock big block set will be even better but will raise the car at least an inch in height.
  #19 (permalink)
Old 10-23-2010, 09:36 AM
Originally Posted by lngliv3
Tony, that thing looks sweeeeeet! But I have to imagine (being from ride tech) that the front of your ride is bagged, and actually rides higher than that normally? If not, how in the hell did you get those meats under the front without rub? Also, all you other guys helping me out....did you look at my plan for 17"'s....does it seem doable?
Hey Ssedan64....I love the stance on yours....is it lowered as well? Looks like a very similar tire to what I have now?
There is no way it is driven like that without a LOT of rubbing so yes it must be bagged.
I am a photo nut and still can't get over what a beautiful shot that is. It's not hard to get a nice shot out on the salt, you just can't go wrong with 24 thousand acres of nothing but flat white salt around you! But the angle, the clouds, it is simply a perfect photo showing the best of that car, very nice!
  #20 (permalink)
Old 10-25-2010, 08:06 AM
Thanks for the props guys... that trip was a blast....
Ingliv, MartinSr... yes you are both correct, that car is on Air Ride all the way around. Ride height is about 2.5-2.75" higher than where it is at in those pictures. In order to get that kind of meat under the front, first we had to fix the geometry and camber gain issues that A bodies inhearently suffer from, Then we had to step up to an 18" wheel to help with clearing a tubular lower control arm... then we just measured the car for the correct backspace wheel. That car there has pulled up to 1.12 lateral G's at putnam Park roadcoarse and that was on D.O.T. rated tires... in fact they were BFG KDW/TA's
  #21 (permalink)
Old 10-25-2010, 11:19 AM
Yeah it is a very cool car but I don't think this is a big dollar project we are talking about in this thread. Tall spindles, tubular A arms and such aren't in this builds future.
But it would be cool huh lngliv3!
  #22 (permalink)
Old 10-25-2010, 04:23 PM
I agree, that photo looks professional! I actually just watched a show on speed the other day that put several well know builders cars against one another in a autocross, roadcourse, and 0-60-0 show down.....Tony, I could have sworn that your chevelle was one of the entries?
Also, back to the backyard chevelle (reality check) Mud Man...I like your idea. I can put the small block springs up front, and maybe use the sway bar idea 2nd, both reasonable price tags.
  #23 (permalink)
Old 10-26-2010, 09:56 AM
Ingliv.... you were probably watching the Optima challenge from last year and yeah we were there for that one We will be running the optima challenge again this year with it to right after SEMA.
  #24 (permalink)
Old 10-26-2010, 09:15 PM
SSedan64's Avatar
I used springs for a Wagon w/AC & cut 1 coil on front, can't remember which springs on rear, I'll see if I can find rear spring Info. Think they were for a 4-door.
Newer Disc spindles & stock Disc brakes.
Actually didn't lower it alot, Engine has Aluminum Heads, Intake, Water Pump & no A/C, so it's much lighter.
Sway bar cold or warm bend? staleg Suspension - Brakes - Steering 3 10-06-2008 10:41 PM
front sway bar 69 chevelle SS Suspension - Brakes - Steering 1 03-28-2004 06:42 PM
Need tire help for Chevelle machgnr General Rodding Tech 10 10-12-2003 08:45 AM
Tire selection and what rim 65 chevelle esears Suspension - Brakes - Steering 0 09-01-2003 08:40 PM
Sway Bar Installation...do it. F-1Rodder Suspension - Brakes - Steering 3 09-19-2002 03:01 PM
