65 Chevelle Wagon 2002 Camaro rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2006, 10:20 PM
34 Ply
Anybody know if the Camaro rear end will go into the 65 Chevelle Wagon width wise and wheel offset wise??? tks in advance Mic 34ply
Old 06-22-2006, 11:49 AM
73oldsman's Avatar
This may help. I let you decipher your cars in questionn year and model from the page. http://www.teufert.net/other/rear%20...dimensions.htm
Old 06-23-2006, 05:35 AM
ZipZ28's Avatar
Nitrous Junkie
Last journal entry: Reflooring The Bed Pt. 2
If it'll help, the Camaro rear with rotors measures 59 1/4" . The rear I'm using in my project is out of a '97 TA, but it'd bolt up under my '01 Camaro. I don't recall the stock Camaro wheel offset as it's listed in mm,, but the Torque Thrust II wheels I run on the back of the Camaro have a 7 1/2" backspacing.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
1955 Ford Wagon Rear End . . . TorqueU Transmission - Rearend 2 10-04-2003 11:33 PM
3rd gen camaro rear stabilizer end links xpence Suspension - Brakes - Steering 1 10-04-2003 08:51 PM
96 camaro rear end fit in 84 regal 225buick Transmission - Rearend 5 04-18-2003 04:10 PM
